jeep0517 said:How are Skyjacker n8088 shocks for the rear shocks after a 2.5" lift? And what is wrong with Rocky Road Outfitters OTT Lift, i keep hearing bad things with no explanation.....
Eddo said:Stay away from the OTT lift unless you don't plan on 4-wheeling at all. They use and over the top strut spacer to create the whole lift. The springs are not stiff enough and since you lowered the mounting point of the strut you will end up bottoming out your struts and that will ruin them pretty fast. The springs just compress too far and you bottom out the strut before you hit the upper bump stop. Also, the a-arms will droop too much because the strut is what limits it's down travel. The mounting point for the strut has been pushed down with the strut spacer. This will result in the upper ball joint contacting the spring eventually ruining the upper ball joint.
RRO knows about these problems and has been contact by probably 15-20 people who installed it and experienced these problems. Everytime they just refuse to admit it is a problem. I cant believe they still actually sell this lift with all its known problems.
You will need longer shocks after a lift. I recommend the Rancho RSX17004, they are the perfect lenght for a lift KJ and what most people seem to run.
jeep0517 said:Eddo said:Stay away from the OTT lift unless you don't plan on 4-wheeling at all. They use and over the top strut spacer to create the whole lift. The springs are not stiff enough and since you lowered the mounting point of the strut you will end up bottoming out your struts and that will ruin them pretty fast. The springs just compress too far and you bottom out the strut before you hit the upper bump stop. Also, the a-arms will droop too much because the strut is what limits it's down travel. The mounting point for the strut has been pushed down with the strut spacer. This will result in the upper ball joint contacting the spring eventually ruining the upper ball joint.
The upper ball joint runs into the spring. Basically the whole wheel will drop or droop until it is stopped by something. Normally the strut is what stops it. Now that you have effectively increased that length of the strut assembly the whole wheel with the a-arms will droop further. The strut no longer limits the droop because you have pushed the strut down further with the over the top spacer. Thus the upper control arm runs into the spring because the wheel has moved so far down. It just happens that usually the upper ball joint is what contacts the spring. Go underneath your jeep and look at the upper a-arm. Now imaging the wheel dropping and the arm coming down with it. You will see that the upper control arm will hit the spring eventually.
As far as in the strut spacer, they DO NOT increase the spring rate. They increase the spring pre-load or pre-tension. Similar concepts and can have some similar perceived effects, but yet different. Yes it can make the ride seem harsher.
However, the preload on the stock assembly is very low. So what has been done is what RRO calls the combo lift. A little bit of a spacer for some lift but not enough to increase the pre-load too much. Then an over-the-top spacer for a little more lift but not enough to run into upper ball joint contact problems. Combo lift is a very good lift and works well for allot of people on a budget.
Best way is just to go with some longer springs, however that can be more pricey. BTW, longer springs also increase the pre-tension so sometimes you need a longer strut or a top-plate that increases the fully extended length of the strut assembly, thus reliving some pretension but not too much or you run into upper ball joint contact problems and bottoming out struts. The Frankenlift by boulderbars.com really incorporates the what I mentioned above and works very well.
