Service Intervals
jp1
Palmer, Pa
Hey guys...my wife's '04 KJ is quickly approaching 60,000 miles on it and figured it was time to start doing some maintenance to keep it going for a while. However, we can't seem to find the owner's manual. :mad: I've tried to change the oil every 3K miles, but haven't done much else. Can someone please post the recommended maintenance schedule?
Thanks!!
jeepkj02
Holland, Michigan, USA
Every 12K: gear oil f/r
Every 15K: air filter and t-case
Every 30K: ****** fluid/filter change and pcv valve and spark plugs
Every 40K: serp belt
Every 50K: antifreeze
VTNomad
Johnson City, TN
60k
I have an 04 and I'm fast approaching 60k. I went ahead and had my service done at 51k, I'm getting ready to move and wanted to use my mechanic of over 15 years of Jeep ownership in the family.
Here's what he did:
Oil & oil filter change
Air filter change
Tire rotation and balance
Transfer case lube
Transmission flush
He check all the fluid levels, and clarity. He also checked the spark plugs (I have the 90,000 mile plugs). He checked the fluid in the differentials, and it was clean, so he said I could wait until 90,000 miles. It would have cost another $200.
Total cost: Just under $300
Total Time: 2.5 hours
My transmission shifts much smoother now. It shifted hard ever since I bought it new, just though it was a Jeep thing.
Where did you get that?
-Every 3k:
Engine oil+Filter
-Every 6k:
Rotate tires
-Every 15k:
-Front and rear diffs(if you offroad or tow alot)
-Air filter
-30k:
-Tcase(and ******+filter if you tow or offroad)
-Front and rear diffs if they are not done every 15k
-Spark plugs
-PCV
-I also changed the Power steering fluid at 30k
-60k:
-Hoses+Tstat
-Belt
-Anti-Freeze
-******+filter again if you tow or offroad (or if it wasnt done at 30k)
-Tcase
-Spark plugs
Thats just a list I made. May of forgotten some stuff.
Here is my maintance intervals......
--Every 3k:
-Engine oil+Filter
-Rotate tires
-Grease UBJ's/LBJ's
--Every 6k:
-Change t-case fliud
--Every 12k:
-Front and rear diffs(no matter what)
-Wash air filter
--Every 15k:
-Flush ******,change filters
--Every 30k:
-Spark plugs
-PCV
-Power steering fluid
-Change fuel filter
-Flush coolant,change t-stat,hoses,and radaitor cap
--Every 60k:
-Belt
-Brake fluid
jeepkj02
Schedule B out of my 2002 OM. Except I like to change my t-case every 15K instead of the 30K the OM says. Forget to add the PS fluid and tire rotation. Rotate my tires at every 4K and change the PS every 10K. My radiator hoses look good at 70K so I would say it would be okay to change them every other antifreeze change. (100K).
I have a excel spreadsheet of all my maintenance records.
Haha, your service sch amazes me tjkj.
tjkj rides his jeep real hard so his service intervals are different.
MidnightLiberty.....nice find on the service manuals.
jp1
Palmer, Pa
Looks like I got a lot of work ahead of me. Thanks guys.
