first&lastKJ
Our 02 had developed a rough idle. I bought the OEM NGK plugs, new PCV valve (still had original). After I installed the plugs and PCV valve, I cleaned the throttle body. When I started it up the RPM's were up, so I let it idle for a while then took it for a drive and the check engine light come on. I drove to Autozone, by now the RPM's were normal and idle was smoother. I went ahead and had them check the KJ and they said it was a code for the throttle position sensor, but they couldn't reset it.
After I drove it some more, the check engine light went out on it's own, Thank goodness!
