Rough start, idles up then dies
SW0_KJ_JEEP
I got this 2006 jeep liberty 3.7l v6 and it's been having rough starting issues and issues keeping started
Here's what I've changed
Fuel pump
Crank sensor
IAC Valve sensor
Throttle body
Throttle body position sensor
MAP sensor
Plugs and Coils
Alternator
Please help I will attach a video soon if it uploads faster
blackhawk
Venezuela
Disconnect the vacuum hose attached to the throttle body..... And see if it helps..
DavidG91
Try giving it some throttle while starting. When I try to start mine warm, I sometimes get a similar issue (see the links) despite several parts replacements (and even a new engine). I've never seen the issue when giving it some throttle while starting.
SW0_KJ_JEEP
The alternator has been changed since these clips but still no difference
SW0_KJ_JEEP
Try giving it some throttle while starting. When I try to stay mine warm, I sometimes get a similar issue (see the links) despite several parts replacements (and even a new engine). I've never seen the issue when giving it some throttle while starting.
When given any throttle it dies
SW0_KJ_JEEP
We got it to start after spraying gumout through the schrader valve on the fuel rail so probably was a blockage from sitting for so long or bad fuel from previous owners
That sounds similar to mine. Nothing solved it for me except giving it some gas as I start it.
