roof rail take off, add real roof rack rails
tonyiiiafl
I have just some fake roof rails on my 08 liberty. How do I remove them? I am figuring out how to remove the real roof rack rails from the donor 2010. I have the rubber type expansion nuts (used them years ago and they were great. when i remount on the 08
The fake rails are held on by 3M tape. You can carefully peel them off. There are studs for the real roof rack hidden under them. The real rack on your donor Jeep comes off by pulling up on the end caps to disengage them, and then unscrewing the acorn nuts from the studs. Pretty easy once you see it.
tonyiiiafl
Thank you! All of you are a wealth of knowledge.
mandala1111
I had the fake rails and as mentioned they are glued on. They also clip on quite snuggly to the roof studs which are M6 so require a firm pull to remove. The glue is a pain to remove, I soaked mine in citrus solvent for a while which softens it making it easier to remove with a plastic scraper. Also with the studs remember the remove all the paint on the threads, a die works well if you have one.
As to using the factory roof racks, they are known to create cracks in the roof around the studs which can cause roof leaks and by having a good look at them I would agree, they are not the solidest of things. That's why I built my own Prinsu style rack out of stainless and alloy which is so ridiculously solid with zero flex or movement which is the issue with the factory racks, they flex too much when loaded up. I have a roof top tent on mine and 270 awning so it needed it to be really solid.
Oh and remember to put some silicone under the rails when fitting whichever route you go and be mindful our KK's only have a 72kg roof load limit. Good luck.
tonyiiiafl
They came off easily on the donor. So when I remove the fake ones on my 2008 the studs are already in there?
JJSalaz
How difficult was making your own style rack? I want to do the same, and did you make it by just bolting it onto the studs that are under the fake rail, because I have the same fake ones?
