Revtek Lift Installed!
AbsoluteRenegade
rochester ny
Well I popped on the Revtek lift last night. As some of you might recall I'm working at a slight disadvantage due to slicing through a few tendons so I'm still sore/not much strenght in my right hand(I'm right handed)Took a little longer as I had to go buy a 21mm socket after I took my tires off (My mechanics set goes to 19mm, der)I went and rented a spring compress for the rear (which ended up not working, because they're idiots and gave me the wrong size) and a strut compressor (thank god for impact guns)and rented a ball joint sepparator (you dont need this for the upper ball joints whatsoever, just jack up the rotor)It was great having my highlift and my 3 ton jack. I'll post up pictures as soon as I find my camera (girlfriend cant find it)I want some pics of my truck sitting next to my roommates new columbia edition. Oh, with the rear, I just removed the sway bar and stepped on the rotor with a foot and slid the springs in on each side, did each NEW shock from 03 Durango and called it a night. My neighbors must hate me from impacting until 3am but thats ok.
JeepnJer
Phoenix
As some of you might recall I'm working at a slight disadvantage due to slicing through a few tendons so I'm still sore/not much strenght in my right hand(I'm right handed).
Wow maan! That slice looks fairly deep. Can I ask how you did that,
and what the prognosis is?
AbsoluteRenegade
rochester ny
My dining room window was broken, and my buddy who lives here took the bottom half out, never taking out the top, when i went to close the window glass dropped and guiloteened me(not sure on spelling)i sliced through my tendons that move my pinky and ring and lost movement, had surgery, gaining most, but i still can make a tight fist. still really sore, hurts today from doing all that lift stuff.
Cableguy
Flori-duh
of the lift mind you, not the tendons! :) Go find your camera already! I don't think i can ever look at the picture of your wrist again. (blarg)
azmotoman
Mesa, AZ/U.S. (immigrant haven)
Rev Tek is the way we went. The 2" seems to be perfect for where we like to go. Just enough to get it up there without feeling "squirrely" and doesn't cause any serious angle issues with the CV's.
AbsoluteRenegade
rochester ny
my angles look perfect, near stock even, i dont think this will cause problems whatsoever
