Replacing rear tri link
jeeptorino68
Oregon
So I would like to get this replaced. Looking at the moog replacement, moot usually does well for me, any experience with it here, or just stick with mopar?
Also I have Als tri link extensio, bracket to install at the same time, any experience on that?
Lancer
South East London
That's the combo that I had installed on mine about 3 months ago. The chap I used is a Jeep mechanic who builds custom jeeps. He compared the Moog to the Mopar and could find no real difference in material or build quality and he thought the balljoint on the Moog was better, so we went with that and the Mopar was returned to the supplier.
He found the threads on here about installing the tri link really helpful - especially Tommud's; he is not very impressed with jba's instruction sheets. The boomerang now sits level and the slight vibration that has been there since the jeep was lifted about 6 years ago has gone.
My last 2 boomerangs were Mopar; the Moog was a lot less expensive. Even if it only lasts as long as the Mopars, I'm doing well! If it wears out quicker, Mopar will go in.
I've tried a couple of the cheaper ones, 3-4 months is all I got out of them, but then I do tend to be a little heavy on the throttle at times, well most times, well maybe everytime I take off
I got a Mopar one with 60k miles from the junkyard for $60 for when mine goes bad.
jeeptorino68
Oregon
Thanks! I will probably go with the moog
Lancer, do you have a link to the threads you are mentioning?
