I understand your suggestion is b/c these are less affected by oil/grease than the OEM rubber...but are these also stiffer since they're poly bushings?It is possible to change the bushings without fully removing the rack, just a little tricky
I recommend replacing with these since oil tends to get on them
2002-2007 Jeep Liberty (KJ) Polyurethane Steering Rack Bushings
Fix loose steering on 2002-2007 Jeep Liberty models. Our polyurethane steering rack bushings resist fluid damage & replace worn OEM rubber.creative-steel.com
