renegade light bar not working!
gatortail
LaBelle, Florida
was in orange grove hunting, was using all lights, turned off all lights and turned off the upper lights and got out.. when i got back in turn the switch on and no lights.... the switch is still illuminated and the dash icon is on , but lights arent working.. took switch apart in grove, see nothing wrong with it...so any body had this problem before/ fuse ? relay? bad switch ?
CzarKJ
Townsend, MA
Check fuses first always. Then trace the wiring (as much as you can). And check the relay.
