remote starter install
Atrus
Metro Detroit, MI
Yes. I picked up the DEI model. You'll also need two working keys to program the model.
Atrus
Metro Detroit, MI
It should lock when you lock the doors. If it doesn't, then you either have a bad mechanism, a bad actuator, or bad wiring.
ShafferNY
Ticonderoga, NY
A piece of advice.
When it comes time to program the bypass module the instructions will call for you to power the ignition up with the use of a jumper wire. Basically what you're doing is programing the bypass module as if it were a extra key.
Rather than mess with a jumper wire, I just went to Wal-Mart and had them cut me a non-transponder key for $1. Then you just stick it in the ignition and turn it to the run position when you need to power up the ignition.
I've installed a Design Tech remote starter in my '03, and I'm currently in the process of upgrading it to a Viper 5101, with a door lock interface module.
www.the12volt.com is a good resource for information, however the forum rules are a bit ****.
