jeepchic79
Well got my build sheet today and it show`s remote keyless entry !!! So i guess that means that i can buy a new one and have it programmed ? Ugh bet thats going to cost a bit ... But it is good to have ..
Did that last month, cost me $216 for remote key and programming.
She has an 02, she can get a key fob off ebay for cheap (around $15) and then have it programmed. She also only needs one programmed by the dealership and can do more on her own.
yes you do need two WORKING sentry keys to program more, i found that out the hard way.... but if you have an EVIC i believe you only need one key fob to program more. correct me if im wrong cuz i will be buying another key fob soon
If you have a key that has the buttons built into it you need 2 working ones to program anymore on your own. If you have a remote that is separate from the key, you only need one programmed to do more on your own.
