Rebuilding a 3.7 looking for a few answers..
69moparfan
Florida
Well my blown head gasket 3.7 has escalated into a dropped seats and damaged pistons. The parts should be ready for reassembly next week, I was hoping someone might has some recommendations regarding:
  • Bed Plate Sealing, type of sealer and technique.
  • Head Gaskets, Copper spray or not
Any other tried and true tips for the trouble free 3.7
Here are some images..
Viewer Discretion is Advised.
JeepCoMJ
SE WI
nooooo need for copper spray,
I used RTV orange high temp on the bedplate.
69moparfan
Florida
Yeah, I was pretty sure about the head gaskets as I have used MLS in the past and I always used them dry. I saw recently online that some people still suggest the spray, I just wanted some other insight.
On the bed plate did you lay out a single bead as stated in the FSM or "coat" the mating surfaces, as it also says...Kinda contradictory.
JeepCoMJ
SE WI
laid a bead then spread it with my silicon gloved hand. didn't use an excessive amount.
69moparfan
Florida
Also wondering about the plates or shims behind the tensioners, I see these come with all the timing kits, but when I pulled my engine apart, there wasn't a shim on either side.
This happened when the Jeep overheated and dropped a valve seat. 1 in each head, #2 and #5 both munched a seat. The heads cleaned up good, needed 1 intake valve, damage to the margins, the bores had some scoring too, .020 over solved that.
Should be assembling this week, maybe installing by the weekend. Can't wait. I've never even driven this truck.
JeepCoMJ
SE WI
I've rebuilt several 3.7l's and have yet to see a shim in, on, near, or around the tensioners.
good luck with the rebuild.
JeepCoMJ
SE WI
I'd also say that the method I used for the bedplate has shown no leaks in over 8000 miles of driving
doolop
here
Just rebuilt my 3.7. Per manufacture use a thin layer of sealant on the bed plate or leaking will occur. Pm me if you would like the shop manual.
Sent from my DROID RAZR using Tapatalk 2
69moparfan
Florida
That's reassuring, it's funny though the FSM makes note of the plate twice:
CAUTION: Plate behind left secondary chain tensioner
could fall into oil pan. Therefore, cover pan
opening.
CAUTION: Ensure the plate between the left secondary
chain tensioner and block is correctly
installed.
I'm certain this engine has never been apart, no plate
I'll use the technique you suggest, I was planning on using Ultra Black, but I went ahead and bought a tube of the Mopar RTV as listed in the FSM, at $6.50 a tube I figured it's cheap insurance.
Thank you for your responses
I appreciate that, I do have one though, I've been wading through it for days. Possibly over reading..
69moparfan
Florida
To any interested parties, it turns out that there was in fact a spacer behind the left tensioner, looks like it is designed to restrict or meter the oil going to the tensioner. It was stuck to the back side. Mystery solved.
