rear shocks
cbpf9
EASTON pa
Just want some opinions on what you guys are running in the back of your kjs? I have an old man emu lift and some xtra spacers currently sitting about 3.25 of lift? Not sure if I should go with Bilstein Iron Man or Old Man Emu or maybe something else and not sure if I should go with something as big as the 4 inch larger ones or stick with one and a half to two inch. I usually driving on the road to little bit off roading once or twice a month nothing too crazy
The OMEs are good for 4 inches of lift, the Ironman are just a bit longer than the OMEs. Both ride very good along with the Bilsteins. I have installed and driven ones with all of them. I would go OME 1st, Ironman as second choice and Bilstein 3rd, only because you already have OME springs so matched to them
cbpf9
EASTON pa
And the ome would be good at around 3" + of lift.. and do they come ready to bolt in with bushings? I heard Bilstein u need to get bushings?
DaleKJ
Hewitt, TX
Bolt On
They just bolt right on just like the stock rear shocks. No bushing is necessary.
OME N132L is what you need. Put them on mine with the OME lift and am very pleased.
