Rear differential pinion seal
timbo68
I'm about to replace my the rear pinion seal on my 2012 Jeep Liberty jet. Some people are telling me that I have to replace the crush sleeves to. Some people and the Internet are saying that this model doesn't have crush sleeves. Is this true? I even looked on YouTube and haven't seen anyone change anything but the seal. Can anyone help me with information on this please?
CheddarGau
Lower Mainland BC
Yes the Chrysler 8.25" does have a crush sleeve. best practice is to replace the crush sleeve. It acts almost like a lock ring by keeping tension on the set up to prevent the nut from backing off. If you decide to re-use it, you will need to increase the pinion nut torque by about 10 ft lbs ish to maintain that tension on the nut. I've re-used them in the past on different vehicles , but really comes down to how I feel about the vehicle at the time
duderz7
Weiser, ID
Mark it well and turn it in just a bit further, this should compensate for bearing wear and crush the sleeve just a bit. Like most metal once the sleeve is no longer under tension it may relax a bit too so the extra bit may not be necessary. Hard to say without actually putting your hands on it. The torque spec is quite high on that nut. I bought a 4 foot 1/2 inch drive breaker bar just for the occasion.
