rear coil spring removal
mx3_ryder
troy VT
Is the bottle jack method the way to go when removing the rear springs or is there a quicker way to do this? Thanks in advance and Happy Holidays
Gyro
Nova Scotia
Stuffing the opposite axle helps get the stock springs out ,and just a few cranks on the compressers to get the OME springs in.
With both shocks removed of course.
Gyro
twowings
Tulsa, OK
A friend with a long prybar can be invaluable here, as well....you will need to apply a bit of force on the axle to get the 2nd rear OME in if not compressed...but it can be done...
Remove shock, stock springs fall out
OME etc , 2X4 , pry down , pop out
or the jack method if installing 4 inch ( plus some extras )
4x4kayak2112
tx
I can just remove my shocks and the entire rear end will drop low enough to fit 5.5" springs no problem
Sent from my SM-N900P using Tapatalk
mx3_ryder
troy VT
I am going to have a buddy assemble the front for me at his shop, but do I need to rent a spring compressor for the rear? Will it make the job easier?
TwoBobsKJ
Northern Ohio
NO on the spring compressor! If a friend is with you, jack up the opposite side then have your buddy use a pry bar or 2X4 as a lever to push down the side you're working on. Put the top of the coil in first, slide it up over the hockey puck bumpstop on the bottom perch and "Voila!" You've just installed a rear spring.
Believe me, it will take far longer to move the jack around and keeping your buddy's attention on what he's doing than it will to put the springs in :happy175:
Have a shop disassemble your front springs/shocks and reassemble them with the new springs/shocks while you and your friend are doing the rear springs. Go get the fronts after you're done with the rears, come back and put the fronts in then get an alignment. You'll be grilling burgers and drinking adult beverages by dinner time :waytogo:
GYPSY400
Sudbury, ON
I just finished mine.. had the boomerang out.. removed the shock bolt and had no troubles installing the ironman springs
Sent from my SGH-I747M using Tapatalk
mx3_ryder
troy VT
I should be able to drill and add bump stops in rear with springs already installed correct?
wheeee32
Not the mountains.
It really isn't too rough a task compared to the front if you've never did it before. I was all smiles after completing the back on my Liberty after having fun on the front. The back was cake.:party52:
mx3_ryder
troy VT
How long of bolts will I need for 2 pucks and what size thread do you use? Would like to pick them up at the hardware store before I get started today. Thanks
TwoBobsKJ
Northern Ohio
How long of bolts will I need for 2 pucks and what size thread to you use? Would like to pick them up at the hardware store before I get started today. Thanks
4 inch carriage bolts with nut and washers, 1/4" or 3/16" should be fine.
Pucks are one inch thick each so 2.25 or 2.5 inch bolt is long enough for two
washer on top and bottom , I use 1/4 or 3/8 inch bolts on most everyones
I use regular bolts due to if you ever need to remove them carriage bolts can be a huge PITA
Nothing against what Bob just quoted but from experience
used to use carriage bolts but switched over:icon_lol:
mx3_ryder
troy VT
Do I need to unbolt rear bolt joint to get springs in? Can't figure out how to do this. Front was easy for me but struggling with rear. Where do I place jacks etc.
Not hard, remove shocks, remove springs, drill holes, reinstall springs, then put the hockey pucks in through the springs , run bolt down through spring pad , tighten up bolt, install shocks . D O N E
VERY easy takes 30 minutes at most
Oh jack up the rear ( of course) jack stands in front of the LCAs and drop the rear diff down
mx3_ryder
troy VT
Well thanks but that didnt tell me anything I don't already know. I needed to know where to jack and where not to jack to remove springs. I rested the body on stands and jacked up opposite side compressing spring while using bottle jack on the side I was removing and worked like a charm.
