Radiator Question
joydyhee
Harwinton, CT
Hi All,
First post! I have been reading a bunch of radiator threads, but unfortunately the answer to my question eludes me.
My wife has a 2005 KJ Limited for which I am replacing the radiator. I ordered a CSF #3363 radiator (I know, not the best brand) from Quadratec and it is exactly the same except for two holes on the passenger side which are not on the original radiator.
Based on their position, am I correct in assuming these are for transmission cooling lines? If so, they are unneeded for my replacement as the Jeep has a separate ****** cooler. However, I do want to plug them, even if nothing is flowing through them, so no debris/critters get in there.
Thus my dilemma - looks like a 5/8" diameter bolt will fit, yet the thread pattern is wrong. Went to both Auto Zone and Lowes with radiator in hand looking for brass pipe fittings and none of those worked either.
Thoughts? Should I not worry about them and just leave them or cover with duct tape? I just want to make sure I can wrap this up with no issues. Any input is appreciated.
Thanks!
jeeptorino68
Oregon
if you want to cap them they are going to be a pipe thread. (NPT) look for some brass fittings. napa usually has them
Cardhu
Great White North
I would hook them up. its much more useful then the stand alone cooler, and you can run both.
TwoBobsKJ
Northern Ohio
That's what I did. Brass fittings were purchased from NAPA - two threaded nipples for the radiator, two unions to join the existing lines to new lines into and out of the radiator. Bought 3 feet of 3/8" transmission hose (only used 2 feet), two 4-packs hose clamps - total cost of the parts less than $15. Here's a pic:
hectikart
Wilmington NC
Hi and thanks for the response. So, to be clear, you did the same and left them open with no issues? If so, you just made my day.
Yes, I left them open with no issue. But I like what I see from TwoBobsKJ...so I think I'll be doing that soon.
