radiator overflow tubing size?
duderz7
Weiser, ID
Just pull it off and go to the auto parts store. They sell it by the for, and it's cheap.
yeah. they only had fuel lines for those ID sizes. >$5 a foot
o.o
The tube that came w/ the aftermarket replacement overflow tank was way too short.
Just as I was enjoying some :birgits_tiredcoffee
Off to the Jeep I go with micrometer, and locate the part number..:gr_grin:
Hope this helps in some way...
:favorites13:
Hehe
Thanks Tim!!
You're awesome.
I was going to borrow a linear caliper from work to measure it too.
Okay. the nipple OD for the overflow tube on the tank is 0.378", calling that 3/8".
so this gates should technically work
GATES 27555 Radiator Overflow Hose; - 5/16" (3/8" Nipple)
I'll be also buying the 27556 as well just in case.
will report back later.
Good Work Brian ! 96 cents per foot that is much more reasonable.
Were you able to measure how many feet required, it is quite long back to the rad.
Even though I would really have liked to measure the nipple for you, it was just too HOT & did not want to get burned by Hoat ! :gr_grin:
no worries Tim. :)
it's sold in 3 ft lengths on rockauto so I bought 6'.
I estimate that one needs about 3.5 ft.
My hose isn't the original hose so someone with a mopar hose would have to measure the actual length.
You would have been short at 3.5 feet. You will have left overs with 6 feet..
It is hard to measure a snake LOL..Was not going to break out the string & tape !
So from recovery tank to where tape measure began was 16 inches and hose drop 4 inches,
Straight length was an additional 28 inches & a couple of estimated inches for bends in there & = somewhere from 48 to 52 inches LOL..
Looks like I'm missing one of those mounting tabs on the TB.
I'm surprised none of mine have fallen off ! :Big Laugh:
There are 3 small retainers & one large one, on the upper rad hose.
Update: I was silly and didn't read carefully that it was sold in 3' sections only.
Went to Napa to get my WP warrantied and also bought the same 3/8" fuel hose I was using.
The old one was really stiff and the rubber internally was coming off as a ran my finger through.
The length to run it like Tim's picture is just shy of 5'. maybe like 4' 10".
I'll probably look for a silicon hose or maybe a plastic fitting to join the two 3' pieces together.
my upper radiator clip broke in half :(
There are clear plastic fuel lines, which are fairly flexible & available as well.
Sorry you broke the rad clip, & no you cant have mine ! :) Bone yard might one, or the dealer.
hahahaha. Thanks.
I just have it ziptied loosely to the upper rad hose.
Hopefully no more leaks. I had to put jb weld on a couple of spots on the mating surface. I had a bunch of pin head sized holes!
