kb0nly
Anyone know the hose diameter on the KJ?? The reason i ask is simply this, i wanted to get a block heater installed but i would prefer to just put one in the lower radiator hose instead of the block, easy to get to and install... I've had that one past vehicles i owned and it always worked good since you could get a higher wattage inline one then an in-block model.
Otherwise i was thinking of getting one of the recirculating block heaters that you put in a heater line, its pumps and heats the coolant... Had one of those on a past truck of mine, those are the bees knees if you can afford one, you could literaly plug it in or set a timer and give it a couple hours and go out and turn on the key and have instant heat before you even start the engine, the engine temp gauge would show near operating temp also.
Last resort i will put one in the block but thats a lot more work, though a couple different shops have quoted me an hour or less labor even if i do it myself i still need to drain and replace coolant for any of these options and that adds cost, so just seeing how cheap i could get it done myself.
