Pulley & Harmonic balancer would this tool work on Liberty 3.7
eagle1one
Hi, I would like to know if this universal removal and install of the pulley and harmonic balancer work on my Liberty 2005 3.7 I hope I am not doing anything wrong by posting this picture?
Thank you
GA05KJ
Atlanta, Georgia, U.S.A.
I used the - ARES 71002 - Harmonic Balancer Puller Kit. Had purchased to replace the leaking front crank seal on my JKU. It worked fine on my KJ's 3.7. Also used the 5 pcs Harmonic Blanacer tool I had bought for the JKU for the KJ as well. The KJ seal was much larger so I just used spacers from my Ball Joint kit. Worked out fine.
njpaulkj
Likely your front seal has been loooongg since replaced, so this is for anyone else out there.
GYRO, JeepJeepster, and GA05KJ all have the right idea. 3 jaw puller, or nothing. That fever for the Vevor ain' doin' shiii.
I used:
ABN 4225 Harmonic Damper Pulley Puller 6-Piece Set for Harmonic Balancer Removal on Chrysler, GM, Mitsubishi Vehicles
NO LONGER AVAILABLE ON AMAZON (I paid $33 in 2023), so you can get a ching-chong $28 copy from Amazon or a green Taiwanese OEMTOOLS 25090 for $45 + $5 for next day home delivery from AUTOZONE. A discount code might be available, too to make it ~$5 less.
IMPORTANT TO USE AN INSTALLER TOOL so you do not overdrive the pulley onto the tapered crankshaft mounting stub, past the finely finished seal surface AND so your accesories serpentine belt is ALIGNED. Just a little important. I used a long pulley holder tool with screw-in posts, too.
OEM TOOLS 37306 Long Reach Installer​
Amazon $40, 2 day delivery with Prime. Autozone no longer sells this.
A Gearoll CR-GZ026 in blue box from Amazon for $28 will work just fine.
I saw a Chinahh-Russian kit Acymner ‎ZH-0730-01 in a blue box for $19 at Amazon, same 2 day shipping, since you like saving money and this is a one or two-time-use kind of tool for anyone. I kinda feel dumb not buying the cheap-azz version.
I bought the OEM Tools, red-case 27306 set in 2023 for $38.
I just wanted the last of the Taiwanese made tools, so there goes $30.
You sure can leave a credit card number with AutoZone or your local auto parts store and get loaner tools, too.
I had my entire timing cover off, so it was easy for me to remove and install the seal(s) using a ball joint C press tool and cups. An OTC SPX 7249 BEAST. (Needed aluminum filled epoxy to repair erosion behind/under one of the coolant o ring type seals. Uuuf. New water pump. New belts. A new hose. A new heater core. A new coolant tank. New coil (one). New cylinder head. New gaskets and seals. Yeah.
eagle1one
I used:
Thanks njpaulkj,
I got the DPTOOL the harmonic balancer remove kit, and the GEAROLL harmonic install tool.
njpaulkj
Thanks njpaulkj,
Excellent! I almost have no doubt they will work just fine for you. ("Almost" only because I did not specifically use these, but I would 100% buy both of them if I did it over again!)
Robochop
Robochop
Virginia
Thank you
If you're only going to do it once, I have used this in the past and it's cheap and works great. It probably wouldn't hold up if you did it all the time tho: https://www.amazon.com/gp/product/B0FF9HC4ZY/ref=ox_sc_act_title_1?smid=A2G9JL7G5QAD63&psc=1
