Pulled inectors.... Hard plastic lower o-ring?
u2slow
BC
I'm sending a head for machining, and carefully pulled out the injectors. The o-rings stayed behind in the bores. Below the green o-ring was a smaller, harder plastic ring. I'm not seeing this part in the o-ring kits.
Any idea where to get this ring? Or do i have to get whole new injectors?
mrlavalamp
Sin City
comes with the injector, I would think you could reuse the hard plastic piece assuming you can get it out intact that is.
u2slow
BC
No, they got torn up on injector removal.
New injectors didnt show up on time, so I re-used the old ones with that missing. They're kinda wiggly in the bores, but the fuel rail supports them well enough. So far so good.
