bmrrwolfe
Next month I will be taking the KJ on its first real road trip, about 500 miles each way, and am looking any pointers to get prepped for the trip.
The Jeep has 92k on her.
So far oil changed last week with a new PCV valve and air filter.
****** pan drop with new filter, about half the fluid replaced and new pan done in November.
Battery last spring.
Plugs over summer.
Dayco Belt and tensioner done about a month ago.
TB cleaned last weekend.
Lucas fuel system cleaner done every 2000 miles or so, will be done in the next week or so.
Diff fluid and t-case fluid done about a year and half ago with 12k, will check and top off fluid if needed.
And added a Pioneer AVH-P1400 double-din in January, just for fun
Plan on draining the coolant cleaning the reservoir this weekend, and doing the rear brakes, fronts were done last year.
Most importantly, the Jeep has a slight shake in the steering wheel when hitting a bump at any speed, its been there probably 6+ months, and I don't really noticing it getting any worse, and when looking under the front end nothing looks or feels worn or broken. I know the rims are straight, had one replaced after a slight bend, and all were rebalanced, and had an alignment late last summer. Drives nice and straight down the highway even at 75-80 MPH. Any ideas? Someone suggested tie rods, someone else suggested sway bar links, but I don't want to start throwing parts at it.
Also any other things to be sure to check? I know I have a good spare, a small compressor, basic tools, full 1/2" socket set, jumper cable, tow rope, spare bulbs, fuses, spare belt and water in the Jeep as well.
Plugs over summer.
