No i havent i am a little nervous to do this but i think i will tomorrow.
there wouldnt be play if it was gasket issue right?
You did mean to say belt, not bolt? And yes that's all there is to it.I forgot to mention it seems to only leak when it has sat overnight... I cant get it to leak if engines warm...
So you just put the wrench right on the pullew bolt on pull clockwise and it releases tension to get bolt loose? makes sense...if so im goin for it
The water jackets inside the engine block are filled with coolant. You have two choices:Did you unhook the bottom hose to dtain radiator?
For a couple dollars more you could have gotten a good waterpump,never buy hard engine parts at autozone.Good luck you will need it.As far as filling the cooling system just fill through the bleed hole in the upper radiator hose(with cap off),once that part is full add coolant to the bottle and run till the t-stat opens.Should never have to add anymore if you fill through the bleed hole 1st.So, I replaced the water pump finally yesterday! The hardest part was getting the lower radiator hose off! They are held on with tension hose clamp and on top of that the hose was attached pretty solid, took awhile! I was a little afraid of damaging the radiator, but I had to go for it because it was 32 degrees outside!
I got a brand new waterpump from autozone for 50$ and it came with lifetime warranty. If anything goes wrong with it as long as I own the vehicle, I get a new pump for free. I was going to replace the thermostat, but it was too cold outside my fingers were numb and I just wanted to get the job done!
I had a question about burping the coolant system. Do you guys think that running the vehicle for 10 minutes with the radiator cap off is enough time to fully burp the system. It bubbled over a good couple of times causing me to have to refill the overflow. I would recommend anyone doing this job to make sure you have a deep socket 13mm and also a 3" extender for the ratched. The extender worked really well to get the bolts finger tight and the deep socket was needed for the torque wrench (40ft/lbs). Thanks everybody for the help!
Look at the upper radiator hose,drivers side of the engine,and you will see a aluminum pipe that that hose connects to on the engine side.There is a plug on top of that,that is the bleed hole and takes a 8mm allen socket.I can't find an image or diagram anywhere for the bleed hole on my 2006 jeep liberty...
the gasket was bad at the bottom right side.
