Plug or wire?
m_volyrakis
Greece
I recently Seafoamed my rig (2.4 '05 export with 55.000 miles), changed engine oil with fresh Amsoil ,
added new Autolite iridium XP sparkplugs #5263, which is what I have been running on for the last 30.000 miles
and for no apparent reason decided to upgrade my ignition wires to Livewires and my coil pack to a Screaming Demon, form Performance distributors
http://www.performancedistributors.com/amclivewires.htm
C9083 Jeep 2.4 Liter 4 Cylinder, 2002-2006 Wrangler SE
http://www.performancedistributors.com/coils.htm
31732 PT Cruiser, Jeep 2.4 02 - 06
Ever since the change my engine had not been working at 100% but I could not point my finger on what was wrong.
It seemed confused form time to time and would sort of stall at high speeds in 6th gear.
I recently got a P0420 code and to cut a long story short, I ended up taking everything apart to find this on #3:
Livewire
AutoliteXP
I have been running the jeep for less than 500 miles since the change.
So, my question is, was it a faulty plug or a faulty wire that caused this?
And for those of you that might think water got into the engine, the answer is no. I have not washed the engine or crossed any rivers since my last plug change.
m_volyrakis
Greece
All the mods are to blame,plugs,wires,and coil.
Why do you say that?care to elaborate?
I was under the impression that Autolites were better than NGKs,
heat insulated silicon wires better than stock
and OEM coils were not as good as Screaming Demons'.
If you have a different opinion I would like to hear it.
Granted the lack of power of the 2.4L I thought this was the best thing I could do, (not considering value for money of course) knowing that this was a way too expensive upgrade considering the small gains..
Bad thing is it backfired..:freak3:
Those iriduim plugs can't handle lots of voltage,the amount a ignition system designed for copper plugs can create.That with a higher output coil and better wires was just a bad combo that sent to much voltage.
m_volyrakis
Greece
Thanks for the reply TJ!
So you're suggesting I go back to NGKs?
or maybe to Autolite single platinum?
Which would be the best plug, granted the specific coil and wires?
