Hello, I am new here, and I just bought a KJ. I have owned a TJ before but this is my first KJ.
The problem I am having is a decently loud humming from the front passenger side. It does not change when you apply throttle except for getting faster as the vehicle speeds up. It sounds like a loud tire hum, but I rotated the tires and no change at all. My next though was wheel bearing on passenger side, but it does not change if I load the bearing by taking turns or sharply loading and unloading it by turning the wheel going straight. It stays at a constant hum.
My second thought after reading some threads online is the passenger side intermediate shaft Is bad which seems to be a common problem. It is a 2002 with 140,000 miles. The noise also stays the same whether is in 4 wheel drive or 2wd.
I don't know if its connected or not either, but it takes a little longer to lock in 4 wheel drive than it should. I pull the handle and I have to drive forward a bit and wait maybe 10 seconds before it finally locks in.
Also, do the front drive shafts constantly turn in it? Or do they not spin with its in 2wd. I'm thinking they are constantly spinning.
Either way I would like to narrow it down so I can stop and get some parts and tear into it this weekend. And if it's not the wheel bearing I'll get the shaft. Although I've also heard it can be a bearing in the shaft. What parts should I buy to have on hand?
Sorry for the rambling post, I typed this on my phone and my big thumbs find the wrong keys sometimes.
