Pcv & excessive oil
Discussion in 'KJ General Discussion' started by Ronin9965, Jan 22, 2020.
  1. Ronin9965
    Ronin9965 New Member
    Dec 11, 2019
    Hey guys question I have a 2003 jeep liberty 3.7 2WD 193,423 MLS. I replaced all the sensors and pcv and breathers. But as the old IAT is covered in oil after a hour drive. I don't have the baffle in the oil fill which I did order. I was wondering if placing a catch can would help keeping oil being sucked into the intake manifold. Any thoughts???
  2. tommudd
    tommudd Moderator Staff Member Moderator
    17,960
    482
    Have you checked the spounge in the air cleaner housing ?
  3. Ronin9965
    Dec 11, 2019
    I didn't see anything like that in housing
  4. uss2defiant
    uss2defiant Full Access Member
    3,414
    74
    can you post pictures?
  5. tommudd
    17,960
    482
    as you are looking down inside the air box, after removing the lid, right side with a hose going to it
  6. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,739
    114
    It'll be in a little holder on the right side. What brand PCV did you use? Aftermarket ones are very hit and miss.
  7. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    7,213
    434
    [​IMG]
    [​IMG]
    This is where Mr. Sponge Bob belongs.
  8. duderz7
    duderz7 Full Access Member
    353
    75
    Jan 20, 2016
    Weiser, ID
    My Sponge Bob is now green. I cut him out of a lawn mower air filter. Just thought I'd mention the idea in case someone is missing theirs. I only had to replace mine because someone had used what looked like fiberglass insulation.
  9. ltd02
    ltd02 Comfortably numb KJ Supporting Member
    2,586
    138
    Not sure 03s had a sponge bob. My 02 did not. Might have started in 04.
  10. uss2defiant
    3,414
    74
    no bob's in early 03s I think.
  11. tommudd
    17,960
    482
    Do you have a PCV running into the air box ????????????????????????????
  12. ltd02
    2,586
    138
    My 02 did not. Breathers ran into the big resonator box sitting in front of the TB.
  13. renegade 04
    renegade 04 Full Access Member
    1,466
    Jan 3, 2014
    Albany New York
    The issue is that your jeep just needs a new pcv valve, mopar has a TSB out for an updated pcv valve.
