OME rear shocks on clearence get them while their still in stock
JJsKJ
Lancaster, Ca.
Note that those are not the extended length versions to use w/ a lift.
The N132L's, afaik, are still Only available at All J Products.
J-Thompson
just south of doucheville
This is correct and wrong at the same time
You can use these with the OME coils ,I do
They are the proper length for factory bump stops
The ones that are longer require longer bump stops = to the longer length
this would negate their extra length
How ever if you are running more lift then you would want the extra length
so you would have some down travel to spare
and yes All J's is the only place to buy the longer shocks
The OME N132's are only 1/2" longer then stock shocks,you only gain a extra 1/2" of flex with them so they are not enough when used with the OME HD coils and no heavy armor.The N132L's are 2.5" longer then stock shocks.
Been running the 132's with my air bags and OME HD springs for years now. Been offroad many times with no issues.
Below,SkyJacker 2.5" lift shocks.............
Below,OME N132's,same lift,same tires,same bumbstops.............
Below,Rancho 17004's(3" longer then stock,about same length as OME N132L's),same lift,same sized tires,same bumbstops.........
Thats an awesome comparison. Theres not a doubt they have more flex but the 132's work just fine. Since I have air bags I dont want to keep them pumped up all the time to limit the upward flex which you must do with longer shocks. Youve got to use the air bags as bump stops since they take place of them.
LibertyOrDeath
Sweet, Rancho shocks make your Jeep invisible. :D
FYI, Les Schwab Tire Centers can get the OME 132L. I got the RMX Monotube shock which was the only other shock available for a lifted Liberty, that they could install. They can get the 17004 but won't install it because Rancho makes it for the Durango.
