Oil on the wheel
martin_metal_88
Quebec,Canada
Some oil ( look red or pink to me ) appeared on my left wheel. I am thinking about left brake hose that punched a hole but can't figure it right now, gonna take care of it tomorrow, what do you guys think?
martin_metal_88
Quebec,Canada
I'll go to check all my fluid level later tonight but it's coming from around the brake disk, then drip on the rim and on the tire while rolling.
martin_metal_88
Quebec,Canada
Well, couldn't find any leak near the PS oil container, or near any liquid container. Found nothing around the brake or even on the inside of the wheel, only on the outside of it and on the tire + some drop on the flare...PS oil is full, as is brake fluid. CV boot is fine to. Wierd...
Clean it and see if it comes back. Brake fluid is clear I thought?
Leeann
Maryland
^ yup, clear/light amber.
Only PS fluid, transmission fluid, transfer case fluid should be red, with coolant a dark pink/light red.
martin_metal_88
Quebec,Canada
I'll see if it come back. Since all the fluid are still full it's not a big deal or a very urgent leak. Gonna get it fixed if I can figure where it come from.
TwoBobsKJ
Northern Ohio
What about the radiator? The usual place for them to crack is around the upper hose on the driver's side - it could be running down the radiator and being blown back to the front wheel area while you're driving.
martin_metal_88
Quebec,Canada
I'll take a look at it on my next day free. I took it to the mechanic in my building on my lunch and on a quick look in found nothing. No liquid inside the wheel or in the engine compartment no liquid at all but on the exterior of the wheel...wierd
martin_metal_88
Quebec,Canada
Just a quick question about the Steering rack, does it have any symptom when it goes bad. I have noticed a few clung when completly turning the wheel at low speed.
