HELP ME ON OIL TRANSMISION LINES!!
gabrielsux
FLORIDA
Hello everyone, a pleasure to greet you, good morning, I have a problem. This is my first post. I think I'm in the right place. It's a detail that I have with my Jeep Liberty 2003 Renegade a year ago. I bought a radiator on eBay but it came out bad. It lasted only a year and apart from that I had to cut the inlet and outlet pipes to the transmission radiator and now I have a radiator that fits perfectly with the original measurements and I can't get those tubes anywhere. Will anyone know where? I leave a photo for more details of what I really cut was the burr of the tube because it didn't even enter the radiator
So you cut the external piece off both tube's? I'd take what you have left and see if you can match it at Napa or Carquest. Dorman makes replacement pieces like this.
gabrielsux
FLORIDA
Yeah i do maybe I shouldn't have done it but there's no turning back I was looking on eBay and Amazon and they don't even sell the tube only aluminum you say in napa that they make them? I think I haven't seen it either if you have a link I would appreciate it
DadOSix
Cumberland, MD.
How about the transmission ends? Do you still have those as well?
If so - take them to the auto parts store and see if they can match you some compression fittings (unions) and then, if the rest of the lines are missing - use some NiCopp to bend your own.
gabrielsux
FLORIDA
Hello doing yeah i try but the weekend goin to junk yard maybe with lucky have one if not sure I need try this possibly
joshgoble
Setting on 37x13.5x 17
Baird TX
Well you could go to a wrecking yard and remove them from a vehicle you could buy a transmission line flaring tool and build your own . Or you can unscrew the plugs in the side of the transmission go back to a 1/2-in NPT threaded compression fitting for copper or steal either one. And tie in that way and for future reference things come apart for a reason and a hacksaw or reciprocating saw that's usually not the best mean to taking things apart if you plan to reuse them.
gabrielsux
FLORIDA
Thank u yeah definitely I went to a junk yard and looked for them again but since I have an aluminum radiator it is not a beard until the end like the original and I had to use a union between the radiator and the 5/8 transmission tubes
