Oil filter drip tray
adamkrz
New Britain,CT
Anybody have a part # for the drip tray under the oil filter, I had a local shop do some work and now it's missing - they deny removing it. 2004 3.7 Thanks..
I think he's talking about the drip rail that mounts to the front of the diff, so when you remove the oil filter it funnels the oil over towards the center
with that same description of splash guard oil, it is listed as 53013506AA in the 3.7L section of the part fische. not in the diagram though so not sure.
adamkrz
New Britain,CT
Thanks guy's, I think this must be it, Really makes it cleaner when changing your oil, the shop most likely took it off when changing the steering rack bushings and whatever.
I'm going to say it was a 4WD only thing. A 2WD one wouldn't need it, since it's pretty much a straight shot down from the oil filter, no diff in the way. Plus 2WD wouldn't have had skids and the drainage tray directs the oil through a hole in the skid.
Ronald
New York
Your question about product #53013816AA from Mopar Parts Webstore
