Odd defroster operation
Kruzn
Central Illinois
OK, so our 2006 Liberty heat/def/AC works great...until the last couple days.
It's been really cold here and on the way to work yesterday I could not get the mode to switch out of defrost until I was half way to work (about 10 minutes).
It did it again this morning. I went out to start the Jeep to let it warm up and the defroster vents were getting all the airflow regardless of where the mode knob was positioned. When I came back out to head to work, it finally switched to floor/dash after I turned it off and back on again.
Is this some weird normal operation (default to defrost) in cold weather, or do I have a control module or door motor going south on me?
Thanks!
I'm guessing you have a vacuum leak. Might self seal once it warms up, but the default mode when there's a leak is feet/defrost.
renegade 04
Albany New York
I had an issue where the selector was getting very slow and as it turned out there was a broken vacuum tee under the hood located under the coolant tank.
