OBD II light
riptricket
OKLAHOMA
So I was driving and all of a sudden it came on.
went to Auto Zone today and it was a 0700 and 0740.
Something with transmission, but I can't remember where the codes are on here.
Anyone know how to fix this?
Thanks!
Minimike
Fort Frances, ON
Well the P0700 code is a TCM code, and P0740 I believe refers to a TCC (Torque Converter Clutch) circuit issue.
For both issues make sure to check the grounds are all good. Check for broken wires going to and from the transmission. If you have these codes and no other you may just have a wiring problem. I hope you find an obvious simple problem.
My advice - don't wait for your ****** to fix itself. Both of those codes are telegraphing some significant issues in your transmission that will be very costly.
Go to a good trans shop and have them put your Jeep on their scanner. It will pull read outs specific to the ****** and give a report on what's happening internally. The longer you wait the more damage will be done.
Let us know what the shop says...
riptricket
OKLAHOMA
My brother used his scan guage tool that hooks up to his laptop, and we can not get the error code to repeat. Even 100 miles later and variable speeds.
Maybe it was a glitch?
Minimike
Fort Frances, ON
This sort of intermittent issue is usually a wiring issue. A good pot hole and the wires are not touching, one more good bump and they are back. I would still look for broken wires and damaged connectors.
Minimike
Fort Frances, ON
I don't have any wiring diagrams or the ability to take under vehicle pictures (1' of snow outside). I hope someone can guide you. But you will want to look at the TCM connectors and wires running underneath the vehicle.
