No Start, Key Won’t Turn Far Enough
CherokeeLiberty
Northern MN
Well, I got stranded while Grocery shopping today. I came back outside, pushed the clutch, turned the key, and nothing! Power accessories turned on, but nothing to the starter. So, I moved some relays around, and still nothing. I tried starting in 4Low to bypass the clutch switch, and still nothing. I currently have the steering column opened up, and I am leaning towards either the ignition switch or the actuating pin.
Tools’s I’ve needed so far are a T20 to remove the column covers, and a safety torx will be needed to move further (sets are available at Menards for $5 or less).
Edit: T10 Safety Torx bit is what was needed.
CherokeeLiberty
Northern MN
Ok, problem has been located, and it’s temporarily fixed.
The culprit ended up being the actuating pin. The end that plugs into the ignition switch broke.
In the meantime, I’ll be sporting a screwdriver. I do need to hold a key right next to the slot, otherwise the engine dies after two seconds. It’ll be an interesting week.
Hopefully this helps someone down the road.
Billwill
White River, South Africa
This is actually a common problem for some years now. Using a screwdriver is a good idea....been there done that!
The Dealers normally do not sell the Actuator Pin Assembly...they told me I have to buy the whole steering column assembly!
My fault turned out to be a wiring issue but the Actuator Pin Assembly can apparently be obtained from Dorman!
Normally you need to have the ignition key inserted in its slot so that the SKEES system can read the code off the key...also the steering lock needs to be disabled....I have long since pulled the steering lock hardware out!
CherokeeLiberty
Northern MN
I ordered the Dorman part from Rock Auto: DORMAN 924704
Oddly enough, Napa’s Echlin line has this too, but they want $100 for it, while RA is $43. I’ve never seen that big of a difference…
  • Like
Reactions: JRB
JibeHo22
How many miles are on your vehicle? I'm wondering if I should replace the part on my 2005 Liberty now, before it actually falls.
Jeremy-WI
Home
I have close to 170k on my 2006 and haven't had to replace that part but I do have a remote start installed so I won't be stranded if it does break
CherokeeLiberty
Northern MN
196k miles. Honestly, with the pin being pot metal, it could happen at any time. If you feel so inclined, keep a new one in your vehicle along with T20 and Security T10 drivers. It’s a freak thing.
JibeHo22
Thanks for the details. I think I will just go ahead and replace the part now with a new one so it doesn't fail when I am in the backcountry.
CherokeeLiberty
Northern MN
Update… You know that button by the ignition that you have to press to turn your key to remove? Well, it self disabled itself the other day. Something broke, and now I don’t have to press it anymore ‍♂️
  • Like
Reactions: JRB
