no lights on night dashbord + right sidelights ( little white front + red rear )
FRANCE
Hello from France with my 2,8L CRD Europe model ( 2 lights inside the Front lights, not like in the US seems...)
Okay 2 weeks ago i drive into a 1m deepth river on 2m lenght, not a good idea but too late.
I loose the front ID metal plate but refixed since.
I have lights problem and i have a basic question on internal relay located inside left of the handwheel ( picture enclosed ).
There is 2 or 1 relay in your KJ with the fuses ?
The one called daytime running lights is missing in my KJ. I am the owner since January 2023.
I replaced this morning the defective white and red sidelights but not working, i have a problem elsewhere...
Cheers.
OLIVIER
I will take a picture of mine tomorrow, it's a UK spec so should be similar to the EU one.
If you search on here there is a link to a site you can download the manuals with wiring diagrams for the Jeep.
Deb'nKJ
KJ's are too old for DRL's to be mandatory on European export models ( except, probably, Scandinavia, Italy &, I think, Slovenia i.e. the countries that require daylight headlight use), so that can be ignored.
If front and rear lights on the same side don't work, it's probably the fuse.
I can't now remember which side fuse is also for the dash lights - & my KJ is 350km away, so can't check until the weekend.
Jeremy-WI
Home
It may be fuses 7 & 9 for the lights, I am sure they are red fuses(10 amp)
Mine is the same
