I installed fog lights on my Liberty, and after reconecting the battery i tried to start it, and nothing.
Everything works in the ignition on position, when i turn the key to the start position i get no crank.
Ive checked all the fuses and relays for the starter and ignition system. Replaced the ignition switch and actuator.
Im simply stumped.
Side info: this is a 2004 Liberty, 3.7L manual 2wd
(For detail sake: i salvaged the foglights, wiring, and column controls from a wrecked 04, after install they work as intended. When the Liberty wouldnt start, i swaped back to my original equipment and still have the same problem.)
Update: a rolling start works, the KJ does start and run from a push start.
Im simply stumped.
