Negative battery cables?
JohnnyGoneWild
PA
Update: Solved the low alternator output! I had a chance to poke around today. I checked all the connections on the charging system and noticed the Alt terminal had some sort of build up on it. Took it off and scraped it down to bare metal. Looked like some adhesive from the heat shrink had moved down. I now have 14.49 volts steady with headlights and blower on.
I'm still going to replace my ground cables. The one going to the engine I'll leave just trim up the end, maybe crimp on a lug ring.
I've heard the word neverstart used a lot in reference to my battery ha. Maybe a new AGM battery is in order too (Santa?)
Thanks a lot guys for all the feedback! I'll post back with any new updates or changes.
JasonJ
Michigan
That would do it.. there's your voltage drop. AGM batteries are great, expensive, but great. Overkill for most applications like ours, however. Get one if you want, or have need, but I wouldn't get one just to have one. Also remember that AGM batteries are not gel-cell batteries, common misconception.
JohnnyGoneWild
PA
I am planning on adding a upgraded sound system. Nothing ridiculous. Maybe even some lights.
I've heard AGMs are better at delivering more consistent voltage across the entire car. Especially under heavy loads?
I guess its overkill now, but I'm looking at a Bosch AGM and Duracell AGM both are on sale for around $150. Im aware of the big battery companies making everything (Johnson controls, East penn) but for me its price vs warranty. 4 year free replacement isn't bad..
I'm not familiar with gel cell batteries. Would Optima be considered gel cell?
renegade 04
Albany New York
Optima is now junk, they use recycled lead and do not last. I had a optima then switch to a diehard platinum, which is really a odyssey battery.
JasonJ
Michigan
You're going to be pushing your alternator harder than the battery... AGM will handle deep discharges better than a traditional lead plate battery... but if you end up deep discharging your battery, that means you've already killed your alternator.
Gunpowder
NorthCentral Indiana
The best and worst batteries can be in the same brand. What was once a good battery may be junk when you replace it with same.
After research for my truck, I went with a Diehard AGM battery in my truck this fall $185 online price honored in store.
My KJ still has 3 yrs on its Napa battery and doing well even with a drain issue we think is in the radio speakers.
As other indicated read only newest ratings. example is the Optima batteries which were rated highly but in recent years manufacturing was switched to china where reliability took a dump.
Optima moved production to Mexico,not china.
Oh and if I remember correctly the battery you bought is made at the same plant as optima's.
There are only a handful of AGM producers.
The Bosh AGM (blue Case) is actually an Exide - Edge.
58192[/ATTACH]"]
and The Duracell looks to be an East-Penn- Dekka
For the price I would go Exide (blue case) good reviews.
I had one in the Jeep under the CanTire Motomaster ultra lablel and it tested new on Midtroncis load tester at 979 CCA.
58194[/ATTACH]"]
The very best Odyssey (EnerSys) AGM are virgin lead and twice the price.
I've got the almost 5 year Old Odyssey back in the Jeep after a good re-charging.
58196[/ATTACH]"]
Gunpowder
58358[/ATTACH]"]
58360[/ATTACH]"]
58362[/ATTACH]"]
I have been looking for an AGM for my '02. Issue is I haven't seen any local that carry a type 86 battery which mine calls for. Napa, Autozone, et all don't even carry AGM in stock. Lots of discontinued models too. I wonder if something happened to a plant? Sure I can find an Odessey on Amazon but who can claim warranty? Who carries Excide AGM's? I think Pepboys carry Bosh but they didn't show any inventory locally for AGM.
Pep boys does have Bosch AGM but limited sizes. I got one for our Toyota Sienna around a year ago but they didn't have the group size for the KJ. I also could not find the right size AGM for the KJ anywhere else.
BTW I really like the Bosch.
You can get Odyssey warrantied at batteries plus stores with proper receipts.
But I doubt you'd need to worry about the warranty,I'll have to remember to bring home and post the battery test I just ran on my old PC1500DT that I retired from my KJ about a year ago.Been at work and using it to run my smoke machine and haven't charged it.At 114 months old(07/07) it still was putting out 700+ cca's(rated at 825) without being charged for a year and almost daily drain from a smoke machine.
Gunpowder
Ya I meant Mexico. Regarding manufacturer. I believe my Diehard is made by Odessey. The case top matches exactly with the ones pictures.
Gunpowder
Not paying $250+ for a battery. The Excide FP-AGM24F looked like it would work but terminals are opposite what the liberty needs (need neg on inside/positive closest to fender.
Have yet to hear anyone have a battery to fit Liberty except for your 1500DT
The Odyssey PC-1500 dual terminal that is now back in Jeep is a group 34/78.
The blue Exide Edge AGM is a group 34 & also gets turned around to fit perfectly.
58364[/ATTACH]"]
Did the 02's have a smaller battery tray, that can not accept a 34 without trimming?
justjeeps
canada
Hello all! First time posting on here..
I discovered a bad ground connection between the engine and chassis. Also the negative cables coming off the battery terminal are very coroded. I figured I would replace the negative to chassis, negative to engine block, and engine to chassis cables. Trouble is I can't find where the negative cable attaches to the engine. Do I get to it above or underneath? I tried following the negative cable down but it gets lost in a web of wires.
Also, anyone who has replaced all the cables have any advice?
Thanks a lot!
my 02 has a double nutted stud with a small hex head on the end.. I brake the connector off before I realized and a 10 min job turned into two days trying to solider a short extension back on. Mind you I went to the depot and secured a regular bolt...and installed my new connector.
