Need help with Tire options on wide wheels
street_jeepKJ
Richmond, VA
hi everyone,
I have a set of 17x9 (front) and 17x10.5 (rear) deep dish wheels which I have made a custom Jeep centercaps.
I wanto to run them on my 2WD jeep permanently but they have low profile tires currently. (have already fitted and run great with no issues)
I want to know what size suv tire I could use that would fit good since they are wider than my stock wheels and staggered.
I currently have 245-65-17 (front) 265-65-17 (rear) on my stock 17" jeep wheels and want the same look for the wider wheels. (taller tires)
so I need to know what size tire I could fit and good suggestions for brands because I want a good off road tire that is good in the street as well.
looking for suggestions since I get mixed info at tire shops,
thanks for the help
Hard to say without knowing if you are lifted or stock
If stock then how much sag do you have?
What the backspacing on the wheels are
It all depends on the above to say what size will work, PLUS the fact I'm sure at some point you'd like to be able to turn the wheels enough to head back home
