So i bought the start to what could be a very beautiful truck. I bought a 2003 Jeep Liberty Renegade, but i need a 3 inch lift. ASAP, i was shopping for some OME, but all i could find anywhere was 1.5. so im asking some other owners of lifted renegades for some help. i would like 3 inches with some 33s under it and some rockstar rims. any help is appreciated, thanks!
Good info above
will add 1.5 is advertised height on OME, you get 2.5 inches in real life
If wanting 3 then you can add a 1/4 inch top plate from JBA for 3 inches of lift in front, add one upper rear isolator to level it out
As far as wheel choice, would try something else, haven't seen any that will work good on a KJ
Stick with 7 inch wide and 4 inches of backspacing or 8 inch wide and 5 inches of backspacing
Tires 245-75-16 or 265-70-16 almost same height but 265-70 are wider of course
Doesn't matter if you have a Renegade or whatever model all are the same, front springs/shocks same from 02-12
