RenegadeBullitt
I decided to get a roof rack right before Christmas. Found the one I wanted on amazon and ordered it. It is a Curt and it seems to be very high quality. The main reason I got the rack was because I bought a bike rack a few months back without checking to see if it would clear the spare tire. Of course when I went to mount it it wasn't even close. My solution was to go and get a hitch extension. With the extension the rack now worked...but wobbled around way more then I wanted(about 4" anyway it was moved) and I still could not open the door more then 4". So I finally said screw it and bought the rack, I can now throw my spare up top and use my bike rack without the extension and I can even open the hatch 80% of the way with the bike rack folded down. Anyways, I had some spare angle steel in my garage and that is what I decided to use for my cross rails. Took me about 3 days to build and $30. All I bought were 2 2" pvc couplings and 4 U-Bolts. I cut my Steel down to the lengths I wanted it, measure everything out, drilled my holes, cut my couplings and mounted everything. Once it was where I liked it I pulled it all back apart and primed and painted using Bedliner paint. (It sounds simple when typing it out...yet I got very frustrated many times and it took me 2 full days to complete...) I am 100% happy with how it turned out. Finished it all up last weekend and this weekend I decided to change my front brake pads, front and rear diff fluids, 5 tire rotation and some other stuff. Also decided to repaint some stuff while I was at it. Here are some pictures of the work in my garage.
Cross Bars with U-Bolts and Couplings
New Reverse Lights
Rear Diff. Cover
Front Skid
Spare Tire Bracket in Bedliner Paint
Done
New Reverse Lights
Rear Diff. Cover
Front Skid
Done
