Mopar Light Bar VS. Roof Rack and KC's
blue_kjR417
Platinum Renegade
Jonesboro, AR
If you want bright might want to look at KC's HID's,sure there expensive but draw about the 1/10th the amps normal lights do and put out 3-10 times the light and and will last much longer.I run two 35watt KC HID's on my ARB,they throw light over 1 miles easy,stops them deer fast,no heat and don't draw alot of amps.KC now has 70watt HID's that turn the night into day,they are super bright.
Haha, I'm paying $250 for 4 100w Daylighters, theres no way I could afford HID's lol but you're right they are amazingly bright!
Ry' N Jen
That is the next step for my Mini!
Four Hella Xenon lamps. Two Free Form Pencil Beams and two Euro Free Form beams.
I Like doing 90+ miles per hour on wet muddy, partially snow covered gravel mountain roads.
I figure I'll take the Bosch 225 Ralley Lamps off of the Mini and use them conjunction with a H.I.D. conversion kit and slap them on the roof of the KJ!
I'm sure I'll look like a real poser then!:D
Ultimately H.I.D. lighting is the only way to go. Less current draw, very little heat output, and way better white light, and longer bulb life.
Ry' N Jen
Just make sure to only use them off road and not be tempted to "Flash" an oncoming vehicle... No matter how tempting!
I did that in my Mini with similar lights and ended up with a hefty fine!
Money better spent on vehicle mods!
