Deb'nKJ
- Joined
- Jun 3, 2022
- Messages
- 539
- Reaction score
- 457
Thought it was time to move on from my introduction, as this might well be the beginning of the end - so far as this KJ is concerned.
Wouldn't normally call it quits this time on a June evening (it's not yet 6 o' clock here) but the weather's cutting up rough - & I'm getting nowhere with replacing this axleshaft. As far as I can see, it's well nigh impossible without a whole lot more dis-assembly (lesson 1: the FSM is as full of lies as Mr Haynes infamous works).
I'm now actually worse off than I was when I gave up the unequal struggle to remove the hub. So, do I pay (assuming I can find somebody prepared to work on it) to get it fixed - or simply to come & take it away? (lesson 2: should've stuck to XJ's).
If your still with me, this is the position:
finally got the shaft out of the back of the bearing/knuckle but, of course, it can't be removed from the diff because it won't pass through the clevis fork - but nobody mentions that)
can't remove knuckle, which seemed like a good idea, to improve access, because the nut on the top ball joint won't turn (either way) although it's right at the end of the thread (oh, & using a rattle gun broke the taper so it just turns) - & that's all that's holding it on now.
still got to remove the hub - because the ABS sensor's sheared off!
(lesson 3: Jeeps of this era are more of a pita than Citroens - quite a revelation in itself)
Not quite in despair - but pretty close, so if anyone has the answer(s), please do tell.
