moaning/humming sound
squirrellydw
PA
I have started to notice a moaning / humming sound coming from the front passenger side I think, any idea?? I notice it the most around 30 mph.
Trodo
Orange County, CA
There is a TSB for brake moan, what year is your Liberty?
BTW that is covered under your warranty, under the first 11,000 miles. After that they feel you're used enough of the brakes to warrant replacement.
Trodo
Orange County, CA
I didn't see anything about the brakes. Another thing it could be, and I also ran into this problem, greese up the front sway bar at the rubber connections good an heavy so that it will spread. I found that after good rains the greese would wash off, and if it was cold, backing out of the driveway, and then turning, the sway bar would rub in its rubber mounts, making a groaning, moaning sound, this sound would go away after it warmed up or had been driven a while.
Here's a list of all tsb's for your Jeep.
TSB Number & Issue Date TSB Title
E14 NOV 05 Recall - A/T Parking Pawl Cup Plug Defect
E02 FEB 05 Recall - Incorrect VECI Label on Vehicle
D46 JAN 05 Recall - Reprogram PCM for Emissions
21-002-06 FEB 06 Engine Controls - MIL ON/DTC P1713 or P1776 Set
14-001-06 JAN 06 Fuel System - MIL ON/DTC P0457 Set
22-002-05 DEC 05 Tire Monitor System - System Information
22-001-05 DEC 05 Wheels - Caring for Chrome Wheels
08-036-05A NOV 05 Engine Controls - A/T in Limp Home Mode/MIL ON
19-008-05A NOV 05 Steering - Revised Power Steering Bleeding
18-037-05 OCT 05 Engine Controls - Flash Programming Failure Recovery
08-055-05 OCT 05 Audio System - Satellite Radio Static
21-018-05 OCT 05 Automatic Transmission - Diagnostic Teardown Procedure
08-013-05A OCT 05 Cell Phone - UConnect(R) Hands Free Phone Inoperative
21-015-05 SEP 05 A/T - 45RFE/545RFE Delayed Engagement After Filter R&R
08-048-05 SEP 05 Brakes/Drivetrain - MIL/ABS Lamps ON/Possible DTC P0501
24-013-05 AUG 05 A/C - Musty Odors When Hot or Humid
21-013-05 AUG 05 M/T - NSG370 6 Speed, Vent Restriction Prevention
23-035-05 JUL 05 Body - Circular/Ring Marks on Glass
18-029-05 JUN 05 Engine Controls - Co-Pilot Support & Correct Cable Usage
08-024-05 MAY 05 Electrical - Radio Equipment Installation Recommendation
23-022-05 APR 05 Interior - Low Gloss Interior Trim Care
21-009-05 MAR 05 A/T - 42RLE MIL ON/Multiple DTC's Set
08-015-05 MAR 05 Engine Controls - PCM Initialization After Replacement
21-006-05 FEB 05 M/T (6 Speed) - Won't Stay in Reverse Gear
08-014-05 FEB 05 Accessories - MOPAR(R) Remote Starter Inoperative
08-012-05 FEB 05 Instruments - TPM Lamp ON/Vehicle Has No TPM System
18-008-05 FEB 05 Engine Controls - Erroneous Ignition Coil DTC's/MIL ON
08-001-05 JAN 05 Lighting - Dome Lamp Won't Turn OFF
08-039-04 DEC 04 Audio System - Left Rear Door Speaker Humming Sound
19-010-04 NOV 04 Power Steering - Additive Prohibition
18-006-04B SEP 04 Engine Control - Generic PCM Programming Procedure
21-010-04 AUG 04 M/T - NSG-370 6 Speed Factory Fluid Fill Level
09-013-04 AUG 04 Engine - Oil Quality/Viscosity Requirements
08-027-04 JUL 04 Safety Systems - Inadvertent Damage/Disabling
08-001-04 JAN 04 Air Bag System - Passenger Air Bag Service Precautions
squirrellydw
PA
fixed
The problem has been fixed. Rotated and balanced the tires fixed it.
