Ry' N Jen
- Joined
- Dec 26, 2006
- Messages
- 9,242
- Reaction score
- 13
I would recommend using standard copper core factory spec spark plugs...
I kept getting a misfire on a cylinder. I had change every thing from coil pack to injector plugs and what it turned out to be was a faulty lash adjuster which kept the valve open slightly. I still had good compression on it but it would still come up a misfire. I opened up the valve cover and replaced the adjuster and the rocker arm because it created a slight flat spot on the roller. After I did that I never got the misfire again. Good luck with it and I hope this helps.
Sold the jeep for 3200 cash dude said he would fix it. Got a 2011 Dodge Nitro. Out of all the jeeps I have ever owned [xj x3,yj,tj,mj] I have to say this has been the worst one.
