Metal screen behind glove box
Is it supposed to come out? Or does it just stay in place? I can't remember for the life of me.
teeje
Toledo
Only part that comes out is the cabin air filter below the windshiel cowl
Sent from my SM-G955U using Tapatalk
I didn't think KJs had a cabin filter? (as in a paper one)
nnote
AZ
Thats where it pulls air for the AC and Heat when you set the dial to recirculate. I've been tempted to try to figure out how to fit a replaceable filter over it.
rjkj2005
US
The kj does not have any cabin filters
Sent from my XT1585 using Tapatalk
Just use a shop vac to carefully vacuum the screen behind glove box and the other one below the windshield cowling.
Ya no cabin air filters, just interior dust from outside..:emotions34:
Do you need to pull the cowling off to get to the other one?
^^^Yeah, "The Pig" is just a unfiltered "dirt sucker"....LOL
Yes-The plastic windshield cowling is easy to remove, lift hood, a few of these plastic clips pull up..
59885[/ATTACH]"]
Then lift it up a bit and disconnect the washer fluid feed hose from underneath.
59887[/ATTACH]"]
Then bend it slightly to remove cowling from from under the hood area, set aside.
Mine was kinda dirty, a moth and other debris stuff.
59889[/ATTACH]"]
Cleaned the screen area with vacuum, screen gave it a light toothbrush w/ soap & water or simple green etc..
I can have the cowling off in a minute now...
Dave ..Did you say "The 'PIG" ? Ha Ha..
59891[/ATTACH]"]
Ya oops you have to remove the arms yes...
Remove the black plastic round cap, remove nut inside.
Spray penetrating fluid in there and pull or pry upward to get arms off.
OEM windshield has alignment marks for blade re-positioning.
59893[/ATTACH]"]
Or can use a marker dot at blade end.
wheeee32
Not the mountains.
Yep wipers definitely need to come off. I cut out some charcoal filter material and put it over the under-hood part. The air coming in to the interior has smelled a little cleaner since then. I check it every oil change.
teeje
Toledo
To all of you doubting, yes that is the cabin air filter. It's not paper. It's a screen under the cowl
teeje
Toledo
It's a metal screen,not a cabin air filter.Just keeps large trash from getting into the fresh air intake and killing the blower motor.
Most of us have quoted it as being a cabin air filter. In essence, it is jeeps stuff out of the hvac
^^you got my "Gas Tank Pig", TC......LOL
Ha ha..Here is a new business card sized, re-fueling reminder Dave!
59903[/ATTACH]"]
:gr_grin:
59905[/ATTACH]"]
:gr_grin:
^^yeah baby, "the golden pig"...LOL
I haven't taken a close look at that metal screen behind the glove box.
Is there room to possibly fab something to put a filter on it?
I take it this is the 'filter' for the recirculation mode?
