ThunderbirdJunkie
Bronze Supporter
Cub Cadets don't count
I am replacing the TC on Grand daughters 2002 liberty. The TC was not able to shift to 2H. Turned out the shift cable was all crammed and bent inside the shifter. I was suspicious of how hard the Tc lever goes from one detent to another.
I picked up a used supposedly excellent TC and it is installed . I tried to shift the TC with a good shifter cable and it wlll not shift to 2H from N. When on the bench the lever needed a larger channel lock pliers to shift through the detents.
The jeep is up on engine stands and I haven't started it yet. I am hoping the situation will change when I get back on ground. That stiff shifting lever has me concerned but maybe running the jeep on ground will answer some questions.
Haha that’s what I do with mine. It doesn’t like shifting between 2hi 4ft and 4pt. It seems reversing works but the tires on the passenger side are 2psi less just cuz I’ve been lazy and haven’t aired them up. Didn’t know that would cause that issue. I also was told that it could be a bushing on my transfer case linkage. Haven’t crawled under there to check yet though.Powerbrake it and if the tires light up, it's in 2wd![]()
