lower a arm bushing replacement?
jramey
kansas city
So I've descovered my bushings in my lower a arms in the front to be the culprit of my mysterious shimmy/wobble. I was curious to see if anyone had a decent write up of how to fix this so I can see what all I will need
Good luck.A torch,50ton press,and alot of cursing after a couple of hours you may get them out.
I bought the correct special tools to remove/install them and they broke in 30 seconds.Just bought new LCA's and was cheaper,easier,and all 3 bushings already installed.
jramey
kansas city
Price for new lowers?
Well crap, its about cheeper to pay a shop to do it
Dealers around here and other places quote about $1200 to replace them,they know how labor intensive it is.If you find a cheaper place they will be hating you,more so the tech as he will loose big $$$ on that job.Good luck.
Oh and a alignment will be needed after also as the LCA mount bolts also set your front camber/caster.
nzoliver
Christchurch, New Zealand
Hi,
Bushes were cheap from Morris 4x4 and a couple of hours per side max. Maybe it cost me NZ$350 (about US$300). I have the upper arm bushes in a box ready to go too!!
Xodius
Las Vegas, NV
Break down for mine (done last year)
Bushings $90
Press out old and in new $110
A couple beers and an afternoon of messing around.
Total: $200 plus beer. Did all but the pressing myself.
BjBnet
Ottawa, Ontario, Canada
I went and bought 2 used ones at the scrap yard off a KJ with about 25k Kms. $100 each, painted them black, slapped them on and never looked back.
yellocoyote
I kind of did the same. I replaced my drivers side LCA with a used one from a donor KJ with 40K miles on them for $50.
Lima.Charlie
Ohio
I replaced the bushings in mine with a press, mapp gas, and some busted toes. I would hit up a junkyard. Much easier and less time involved!
