Low speed rumbling noise
dude1116
Pompton Plains, NJ
Hit it with the BFH alot. FINALLY! Now how to get these stupid corroded clips off...They're so corroded they won't move when I squeeze them.
I need a beer.
02redKJ
Coos Bay Oregon
Also while doing this I found that the rear joint is seized in one of the movement directions. o_O
Found your rumble cause! LOL
My initial knee jerk reaction was going to be "Get a bigger hammer" but I wasn't sure how you would take that! LOL
As for the clips, same advice unless you are trying to reuse them. Then you'll have to use some finesse, tap them in a circle until they loosen up and then grab them with some needle nose pliers. Its a PITA, but don't give up, just keep trying.
dude1116
Pompton Plains, NJ
OK got all 4 on one side and tried whacking the joint out...but it won't budge. There isn't an inner clip that I'm missing is there?
Luke
Interloper
Bancroft, Canada
a press works better ... and you don't risk damaging the yoke. (no clips but the outer)
you can borrow the kits for free from your local auto parts joint.
Cardhu
Great White North
once you get a cap out use a socket to keep the cross in line when you hammer out the other side of the cap. It keeps you from galling the flange yoke thingy when they get out of line.
And yes, a press is ideal. Especially the first time you remove the joints.
make sure you mark them so you don't flip any of the parts over and hopefully your drive shaft is still balanced. otherwise 50 / 50 chance of chasing that.
dude1116
Pompton Plains, NJ
Even with the salt corrosion? I figured the BFH and socket method would work best in that situation.
And thank gosh there are no inner clips.
CactusJacked
Chicago Suburbs
A bench vise and appropriate sized sockets is all I ever use. Some manufacturers fuse the caps into place with a liquid plastic/nylon. Look to see of there are any holes on the ends where the caps press into. If so, you need to melt the stuff out with a torch. Generally though, when the caps are molded in, they don't use clips, but provisions are there for them.
02blue
Do you have a ball joint press? I've modded one of these to do this. Like CactusJacked said A vise is the only other way I've ever done Ujs.
dude1116
Pompton Plains, NJ
So she's ALMOST all put back together. I took her for a test drive because I couldn't resist.
Finaly question: How's everyone keeping their drive shaft boot on? I tried zip ties but the thing wont stay into place. I'm thinking a hose clamp will work...but I have yet to find a hose clamp narrow enough to fit on the boot.I also noticed it looks like there USED to be another clamp on my boot (towards the back end) but it's gone?? I assume that is how that side of the boot is supposed to stay on?
Ziptied mine and stayed put.Used a high quality 175lbs test ziptie,not a cheap one bought at auto zone or wallmart.
Mskeet99
Was the issue the U joint? I have the exact same issue.
