The above link is the Motor Vehicle Act Regulations for Vehicle lighting
I edited it down so it would fit here and only posted the most relative sections
Auxiliary driving lamps
4.09 (1) A motor vehicle may be equipped with 2 auxiliary driving lamps, mounted on the front of the vehicle at a height of not less than 40 cm and not more than 1.06 m, that are capable of displaying only white light.
(2) An auxiliary driving lamp must be directed so that the high intensity portion of the beam is, at a distance of 8 m from the lamp, at least 12 cm below the height of the lamp and, at a distance of 25 m from the lamp, not higher than 1.06 m from the road surface.
(3) An auxiliary driving lamp must operate so that it is illuminated only when the upper beam of a multiple beam headlamp is illuminated.
[en. B.C. Reg. 476/98, s. 2.]
Parking lamps
4.10 (1) A vehicle may be equipped with 2 parking lamps, mounted on the front of the vehicle, that are capable of displaying only white or amber light.
(2) A vehicle may be equipped with 2 parking lamps, mounted on the rear of the vehicle, that are capable of displaying only red light.
Fog lamps
4.11 (1) A motor vehicle may be equipped with 2 fog lamps, mounted on the front of the vehicle below the headlamps, that are capable of displaying only white or amber light.
(2) Each fog lamp must be
(a) mounted not more than 30 cm below the headlamps, and
(b) adjusted and aimed so that, at a distance of 8 m from the lamp, the centre of the beam is at least 10 cm below the height of the fog lamp.
(3) The fog lamp wiring and switch must permit simultaneous operation of the parking lamps, tail lamps, licence plate lamp and, if required, clearance lamps.
(4) The operator of a vehicle may use fog lamps instead of headlamps when atmospheric conditions make the use of headlamps disadvantageous.
Side-marker lamps
4.12 (1) A vehicle may be equipped with
(a) 2 side-marker lamps, mounted on each side of the vehicle near the front, that are capable of displaying only white or amber light, and
(b) 2 side-marker lamps, mounted on each side of the vehicle near the rear, that are capable of displaying only amber or red light.
(2) The side-marker lamps referred to in subsection (1) may operate in conjunction with turn signal lamps or the hazard warning signal.
(3) A vehicle with an overall width of 2.05 m or more, or having a gross weight in excess of 1 400 kg, may be equipped with side-marker lamps mounted on each side of the vehicle at the horizontal mid-point of the vehicle.
Turn signal devices
4.13 (1) A vehicle may be equipped and mounted with
(a) a lamp type turn signal system, or
(b) a semaphore turn signal device,
functionally equivalent to original equipment supplied by the vehicle manufacturer or of a type or make approved by the director.
(2) A lamp type turn signal system must
(a) have 2 lamps, mounted on the front of the vehicle, that are capable of displaying flashes of white or amber light which are visible to the front,
(b) have 2 lamps, mounted on the rear of the vehicle, that are capable of displaying flashes of red or amber light which are visible to the rear,
(c) be visible on each side of the vehicle at a distance of 100 m in normal sunlight at an angle of 45° from the longitudinal axis of the vehicle, and
(d) include a tell-tale lamp which gives a clear indication that the system is activated.
(3) During the time specified in section 4.01, a semaphore turn signal device must be capable of illumination by light or reflection visible from a distance of 100 m.
(4) A public passenger vehicle or a commercial vehicle that weighs more than 4 500 kg may be equipped with supplementary turn signal lamps in addition to the turn signal system required by subsection (2).
(5) A turn signal lamp must be mounted on the vehicle at a height of not less than 38 cm and not more than 1.83 m.
(6) Subsection (5) does not apply to highway construction vehicles, maintenance vehicles, tow cars or vehicles being towed by a tow car.
(7) A vehicle which is being transported in a drive-away/tow-away operation, or is being towed by a tow car, must have turn signals that are synchronized with the turn signals of the towing vehicle when the tow vehicle turn signals are illuminated.
(8) Despite subsection (5), a tow car may be equipped with supplementary turn signal lamps mounted within the maximum allowable vehicle height (4.15 m) and as far forward as the rear of the cab.
(9) The centre of the front signal lamps must be at least 10 cm from the edge of the low beam headlamps
[en. B.C. Reg. 476/98, s. 2; am. B.C. Reg. 135/2003, s.1.]
Cowl and fender lamps
4.14 A vehicle may be equipped with no more than 2 cowl or fender lamps, mounted on each front cowl or front fender of the vehicle, that are capable of displaying only amber or white light visible to the front and amber or red light visible to the rear.
Tail lamps
4.15 (1) A motor vehicle, trailer or semitrailer must be equipped with 2 tail lamps, mounted on the rear of the motor vehicle, trailer or semitrailer, that are capable of displaying only red light visible from a distance of 150 m to the rear on both sides of the motor vehicle, trailer or semitrailer at an angle of 45° from the longitudinal axis of the motor vehicle, trailer or semitrailer.
(2) Despite subsection (1),
(a) a motorcycle may be equipped with only one tail lamp, and
(b) a vehicle manufactured before January 1, 1959 may be equipped with only one tail lamp.
(3) Each tail lamp must be mounted on the vehicle at a height of not less than 38 cm and not more than 1.83 m.
(4) Subsection (3) does not apply to vehicles being towed by a tow car.
(5) Despite subsection (3), a tow car may be equipped with 2 supplemental tail lamps mounted within the maximum allowable vehicle height (4.15 m) and as far forward as the rear of the cab.
(6) A vehicle which is being transported in a drive-away/tow-away operation, or is being towed by a tow car, must have 2 tail lamps that are synchronized with the tail lamps of the towing vehicle when the tow vehicle tail lamps are illuminated.
Licence plate lamp
4.16 (1) The rear licence plate of a vehicle must be illuminated by a lamp that is capable of displaying only white light so that the numbers on the licence plate are legible from a distance of 15 m to the rear of the vehicle.
(2) The lamp required by subsection (1)
(a) must illuminate whenever the headlamps or parking lamps are illuminated, and
(b) must not project white light to the rear of the vehicle.
Stop lamps
4.17 (1) A motor vehicle, trailer or semitrailer on a highway must be equipped with 2 stop lamps, mounted on the rear of the motor vehicle, trailer or semitrailer, that are visible to the rear on both sides of the motor vehicle, trailer or semitrailer at an angle of 45° from the longitudinal axis of the motor vehicle, trailer or semitrailer.
(a) a motorcycle may be equipped with only one stop lamp, and
(b) a vehicle manufactured before January 1, 1959 may be equipped with only one stop lamp.
(3) A stop lamp must be
(a) capable of displaying only red light visible from a distance of 100 m to the rear of the vehicle in normal sunlight,
(b) illuminated exclusively upon application of the service brake, and
(c) mounted on the vehicle at a height not less than 38 cm and not more than 1.83 m.
(4) Subsection (3) (c) does not apply to vehicles being towed by a tow car.
(5) A vehicle may be equipped with one additional centre-mounted stop lamp that is capable of displaying only red light visible to the rear.
(6) A public passenger vehicle may be equipped with 2 supplemental rear stop lamps.
(7) A tow car may be equipped with 2 supplemental rear stop lamps mounted within the maximum allowable vehicle height (4.15 m) and as far forward as the rear of the cab.
(8) A vehicle which is being transported in a drive-away/tow-away operation, or is being towed by a tow car, must be equipped with and illuminate 2 stop lamps that are synchronized with the stop lamps of the towing vehicle when the tow vehicle stop lamps are illuminated.
Backup lamps
4.18 (1) A vehicle may be equipped with not more than 2 backup lamps, mounted on the rear of the vehicle, that are capable of displaying only white light to the rear of the vehicle.
(2) A backup lamp must illuminate only when the vehicle is in reverse gear.
Spot lamps
4.24 (1) A motor vehicle on a highway may be equipped with not more than 2 spot lamps that are capable of displaying only white light.
(2) An illuminated spot lamp must be directed so that the high intensity portion of the beam will not strike the windows, mirrors or occupants of another vehicle.
(3) A spot lamp must be securely fastened to the motor vehicle, and the lamp or control must not interfere with the driver's vision or control of the vehicle.
(4) A spot lamp must not be used in substitution of headlamps.
(5) Subsections (1) to (3) do not apply to emergency vehicles.
Off-road lamps
4.25 Despite section 4.04 (2) (c), a vehicle equipped with off-road lamps when on a highway must have the off-road lamps concealed with opaque covers.
Cheers
Ry'
