Toymanjeep
My lighter socket is powered all of the time. Is there an easy way to change it to only power up when the key is turned on ?
After a little thought, wouldn't it just be simpler to add another one in a different location and power it however you please?
^^^^^ That ^^^^^
There are several switched power sources that could be tapped in to in the fuse block or use an add-a-fuse to get what you want.
I've seen several posts around the interweb that have second and even third aux outlets mounted in the cabin of the KJ.
