Lift kit education needed
mindbomb
California
Hey KJ peeps,
I purchased a 4x4 sport 03' KJ with 45rfe ******, 115k miles never off roaded. Good condition except for some minor interior issues I'm gradually fixing. It's all stock (I got P235/70R16 tires, alloy wheels though) - I want to start off-roading for fun and learn the field gradually. Budget is quite limited.
According to recommendations I got here my path is:
- Lift kit (read on)
- A/T tires (thinking of: 245/75R16)
- some skids (oil can only for starters)
- Bull guard/Winch (need recommendations)
As for Lift kit the direction I was guided is:
OME 927/948 and stock replacement Bilstein shocks
My questions around lift kit are the following: (feel free to answer only some of them, I know it's a lot)
  1. Are these the only parts I need to order to get the 2.5" lift? I've seen people talk about bump stops/hockey pucks etc. What does that do? What else is needed/recommended?
  2. What are the advantages/disadvantages of also replacing the upper control arms? what are their role in the suspension system? should I be thinking of getting also replacement UCAs for this install? Why?
  3. I don't have the knowledge or equipment to do the installation myself - I've been getting quotes in the 350-550$ range for such installation. Legit? What should I be emphasizing to the potential installer? Any particular recommended installers in NorCal?
  4. Installers asked me if "any modification" is required for the install, what should I tell them?
  5. Is there a group of experts I can meet up with in NorCal to do "guided" installation and learn myself?
  6. What will 2.5" of lift let me do? What does this extra clearance provide in terms of benefits over stock while off roading? What type of trails/obstacles I can take once its installed and couldn't before?
  7. Should I expect different handling from the KJ after lift kit is installed? How can I confirm handling is right and alignment was done correctly?
  8. A 2.5" doesn't sound like a lot of difference - Should I consider 4" lift instead? What are the advantages/disadvantages? I guess prices are much higher?
Any info/answers are welcome, many thanks guys!
u2slow
BC
Mine needed upper control arms at 2" lift in because the camber was so far out an alignment was impossible. However, many others have successful alignments without aftermarket UCAs.
Hey KJ peeps,
    YOU HAVE TO HAVE BUMPSTOPS TO PROTECT THE SHOCKS FROM COMPRESSING TOO FAR AND BLOWING THEM OUT
    WHY? ITS A GREAT UPGRADE AND MORE THAN LIKELY YOU ARE DUE FOR NEW ONES ANYWAYS, STOCK YOU HAVE TO REPLACE THE WHOLE ARM, WITH THE JBA'S YOU CAN REPLACE THE BALLJOINT ONLY, I INSTALLED THEM ON MY 2.5 INCH LIFT ON MY 03, HAVE BEEN RUNNING THEM ON MY 04 FOR OVER 100,000 MILES
    BE VERY CAREFUL, MANY HAVE NO IDEA WHEN LIFTING A KJ AT ALL, THEY MAY HAVE DONE XJS ETC
    NO MODS REALLY BUT YOU DO HAVE TO DRILL HOLES IN THE REAR LOWER SPRING PERCH FOR THE BUMPSTOPS
    THERE IS A GREAT GROUP OF FOLKS IN YOUR AREA WITH THE LOSTJEEPS FORUM, CHECK THE CALI SECTION, ALSO HAVE ALLJS UP IN THAT AREA AS WELL, GREAT FOLKS AND CAN DO INSTALLS
    cHECK PICTURES BELOW FOR DIFFERENCES
    WILL HANDLE 100 TIMES BETTER THAN STOCK, I THREW MY STOCK SUSPENSION AWAY AT 20,000 MILES DUE TO BEING SO BAD AND UPGRADED TO OME
    How can I confirm handling is right and alignment was done correctly? ASK FOR A PRINT OUT
LOTS OF DIFFERENCES BETWEEN SAGGED STOCK AND EVEN TWO INCHES TO TWO.FIVE
STOCK WHEN I BOUGHT THE 03 A FEW MONTHS AGO
AFTER 2.5 INCHES OF LIFT, NOTICE ANY CHANGES?
HERE IS ANOTHER ONE WE LIFTED A FEW WEEKS BACK FIRST STOCK HEIGHT THEN 4 INCHES OF LIFT
MY 03 ON THE LEFT WHEN i FIRST GOT IT, MY 04 WITH 4.5 INCHES OF LIFT AND 32S, MY 05 AT STOCK HEIGHT
AS far as install prices I charge 425-475 for a full spring lift, with UCAs I get 525-550 but also depends on year/ amount of rust etc
if any extras like brake lines, if I supply bumpstops so a lot of variables ( if CRD then extra 50-75 )
This includes alignment of course
Front shocks would be same as stock but rears would not be stock ones by the way
heres another great comparison stock sagged CRD that an owner brought to me to lift beside my 04
KJ604
Vancouver BC
Hey KJ peeps,
    Teraflex bumpstops for the front, and two hockey pucks per side for the rear. Bumpstops stop the springs from stacking, which means compressing so far it is metal on metal, and is not good for the spring. That is all the parts you will need for a 2.5" lift. Probably. Some people have needed new a-arms with only the 2.5" lift but from what I have read, *most* people have not needed new a-arms to get a proper alignment with only a 2.5" lift
    JBA's replacement a-arms have a replaceable ball joint with a grease fitting on it. It helps improve the angle of the ball joint on a lifted KJ. And I believe they are recommended for any lifts higher than 2.5" to get a proper alignment
    The two hockey pucks need to be bolted to the rear spring perch, fairly simple. And I have been told there is a small amount of grinding involved to install upgraded a-arms
    You will be able to drive over obstacles that are 2.5" taller than before. :shrug: You will also be able to fit an oversized tire. You are gaining a bit of ground clearance for sure. The new springs will also provide a stiffer ride. Those are both good things when off roading. Tires are important too though. If you want to do trails and things where there could be sharp rocks and things like that make sure youre getting a tire with a strong sidewall that is made for that kind of thing
    The ride will be stiffer and I have not read any complaints about the way the KJ handles after installing a lift. I think most people call it an improvement. If she drives and stops straight then shes probably aligned correctly.
    If you want a 4" lift just get the a-arms, top spacer plate and clevis spacer for the front, gives you about 3.5-3.75" of lift on the front. Then Just add 2 extra upper isolators per side on the rear springs. $30 for the top spacer $18 for the clevis spacer $50 for 4 extra isos. The a-arms are the expensive part of going for the extra lift, but they are a good upgrade over stock.
Answered what I could.
damnit tom
another we did, before and after
brought it by to see if I could find out what was wrong with the ride and many noises. shocks blown out, sitting almost 2 inches below stock height it was a mess
after OME 927s/048s, with 3/8 inch clevis, 1/4 inch top plate JBA UCAs, two extra upper iso's in the rear etc , normal lift we do
so hopefully you can see the advantages plus way better ride and handling
KodiakKJ
Colorado Springs, CO
I would also suggest getting new upper control arms. I installed the OME lift on my kj last month. Mines an 03 with only 106k miles on it and the upper control arm bushings are dry rotted enough that I have to replace them. The alignment was barely able to get into spec with the stock upper control arms, only 0.1 degree away. I have the 926 springs in the front, but when I got used to the height, I can still turn at the same speed as before, but still slow down a little bit more, just to stay safe. The steering did get a little stiffer as well.
