Leaking sunroof
jdogg55
Michigan
I have a leak on the back side of my sunroof on both driver & passenger side corners. I cleaned the drain tubes but this isn't the problem. The last big storm I noticed the rain was actually coming in through those locations. Is this common? Is there an easy fix/adjustment or do I need to take it in for repair?
Thanks for your input
ACWeller
Lansing MI
It sounds like the seal is bad or it's not closing fully. How does it look ? I had this problem with my last car and it only required some minor tweaking of the 4 bolts that hold the glass to the mechanism.
